HELP!! 2013 ML350 Base Aux Battery Malfunction
Can someone please confirm if the Aux battery on the ML350 is in the engine bay, behind the dash or in the right side of the trunk??
Cheers!!
Cheers!!
Cheers!!
I took the voltage using an ohm meter on the old (used) battery and it measures 12.64 volts. It was dropping, but not sure it I should have found a lower number since the computer was asking to to service the Aux Malfunction Battery. I usually got the dash message in the morning upon going to work, so I figure the car was sitting cold and the Aux battery was not recharging.
Anyway I bought a new OEM battery for $48.00 at a MB dealership and did the work anyways. I figure it was the original battery when purchased new in 2013.
Thanks to all again,
Cheers!!
