rear brake pads
Old Nov 18, 2018 | 06:45 PM
gmanz e500's Avatar
2015 ml 400
rear brake pads
hi all
i just finished replacing the rear pads
i used pagid [hella] pads and sensor - seems to be the oe equipment
thx to all who posted the diy info in the various forums
curiously, the right in-board pad was the most worn down, likely setting off the message in the instrument cluster
also, the left in-board pad had separated from it's backing plate, but the rotor was OK
planning to replace the fronts in the next few days
cheers!
m
2015 ml400 41k miles
Old Apr 13, 2019 | 03:44 PM
konigstiger's Avatar
'71 Pinto
Originally Posted by gmanz e500
I have been unable to find documentation on replacing spark plugs for my 2015 ML400, m276.821 engine MB WIS is not very clear can you help?
Concern?
File Type: pdf
File Type: pdf
Old Apr 13, 2019 | 05:41 PM
gmanz e500's Avatar
2015 ml 400
Concern?
Hi Dan
Thanx for the pdfs. I have those.
I was looking for more information re removing the plastic parts which are above the location of the coils
As you know, the V6 twin turbo motor [276.821] does not at all look like the ones pictured in the pdfs [276.952, which I also have in our e350 2013, and the 273].
Cheers!
Malhar.
Old Apr 13, 2019 | 06:41 PM
'71 Pinto
Pull WIS doc AR09.10-P-1150GQC also, see if attachment helps.
Old Apr 13, 2019 | 08:24 PM
gmanz e500's Avatar
2015 ml 400
thx
i had that wis - just needed to read it more thoroughly
i will let you know how it goes
m
