Replace front turn signal with LED bulbs?
Old Dec 16, 2018 | 10:03 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
Hey all,
I have a 2015 ML 350 with the halogen bulbs (ugh). Anyways, I would like to swap out the halogen turn bulbs for LED ones. The service manual makes it appear as if they aren't swappable (the marker lamps, running lamps, low and high beams are all given instructions for replacement, but not the turn signals). I've just ordered LED bulbs for the rear lights, but would like to complete the conversion to all-LED with the front lights. Any ideas?
Old Dec 17, 2018 | 09:40 AM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Make sure the bulbs you buy use as much current (amperage) as the old ones. Or, get load simulators, otherwise you'll get an error message. My reverse bulbs were advertised as error-free, but I get an error message every time I back up. Turns out the replacement LED's were about 20 watts and the OEM's are around 40
Old Dec 18, 2018 | 12:37 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
basically agree with above
Old Oct 15, 2020 | 11:13 AM
imthatmvrk's Avatar
13’ ML550 4MATIC
Has anyone figured out how to get to the front turn signals?
Old Oct 15, 2020 | 12:15 PM
drwolf's Avatar
basically if you wanna do this and your not a DIYer, you should get it professionally done with the correct bulbs so you dont get errors on the BC (board computer)
