How to chang front turn signal bulb 2012 ml350
Old Aug 22, 2019 | 08:11 PM
temoc rosas's Avatar
2012 Mercedes ml350
Hello how are the bulbs changed i didn't want to brake anything
Old Aug 22, 2019 | 09:52 PM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
I don't think they can be changed. They have to be serviced by a factory tech.
Old Sep 30, 2019 | 08:13 AM
GRMNSOL's Avatar
2005 MB C240
There has to be a procedure to replace any bulb. Factory does not have to get involved. Learn from threads out here like I am as to how to do it. I need to change the turn signal bulb in my car and it can't be that hard that a factory technician can only do it.
Old Sep 30, 2019 | 08:19 AM
GLK Super Fan's Avatar
GLK250 ML350
Which one needs to change? Do h have the bi xenon package?
Old Sep 30, 2019 | 06:17 PM
jbarhorst's Avatar
2018 S450 4Matic, 2020 GLE450 4Matic, 2010 S550 4Matic(sold), 2012 ML350 4Matic(sold)
I think you access through the wheel well.
Either there is a panel to open or you remove the inner liner.
I haven't looked specifically at mine for that.
Old Oct 1, 2019 | 02:36 PM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
This isnt the the bi-xenon, the assembly, although its the same shape, completely different.
OP.. i would do the following. Go to pep boys, they'll show you which bulbs you need, but i dont know if they'll do the install (in which you'll only need to pay the labor which is cheap).
OR.. you can go straight to MB dealer
Old Dec 26, 2020 | 12:04 PM
JR106's Avatar
ML250 W166 Bluetec
Angry ML front indicator bulb changes
Looked into this for mine. UK car 2014 ML250 W166 RHD
There are two bulbs per Headlamp
Got at through the bottom of the head lamp
the inner wing panel has to be opened ( the access panel in the liner only gives you access to the Headlamp dip bulb H7 )
The bottom panel/liner has to be opened on the side you are working on ...there is a youtube video for a showing a similar access (not specifically for an ML though) and there is only one bulb not two as in the ML
The ML headlamp from underneath looks like this
two indicator bulbs each holder secured by two (Torx20) screws
The Bulbs also are non standard being a complete Halogen Bulb and Holder Unit held in place by the double screws (Torx 20) in the bottom plate and so require 'fishing out' with long nose pliers or similar
Not the quickest way to change a Bulb ( 12 v 24W Py24W Amber -but check £18 ish in UK ) and perhaps why two bulbs per unit ... you can see why they want you to go to a dealer ! but manageable
Hopefully been of some use to you
Cheers
JC
