Labored Shifting, Limited Power Output
Old Sep 9, 2019 | 11:09 AM
mijotu's Avatar
2004 MB E320 Wagon
I am attempting to arm myself with options and opinions prior to visiting my dealer regarding this 7G transmission issue. Thank you for any contribution.
This truck has and does run beautifully, and this issue only presented itself last week. Basically, it runs out of power and has delayed dramatic upshifts. Here are the finer points:
2014 ML350 Bluetec 4Matic
VIN #4JGDA2EB9EA269079
Trans #72290304971195
119K miles
Symptoms, from a stop:
  1. Accelerates normally (from what I can briefly sense) to 2500 rpm, then maintains the same velocity/power before finally upshifting several seconds later (@3000 rpm)
  2. Repeats this behavior for each subsequent gear
  3. Upshift is delayed, with a soft “jerky” engagement of subsequent gear
  4. Modulating the throttle (from light to full acceleration positions) has no strong effect on engine speed/power output
  5. Slowly accelerates to normal highway speeds (approx 10-12 sec from stop), with no increase in available power at any road speed
  6. Fails to respond to paddle shifter input
  7. Activates CEL only half of the time
  8. Issue disappears or “resets” after powering key off
  9. Frequency of issue increasing from occasional to frequent over a period of one week of steady driving (currently parked)
  10. No transmission related codes seem to appear on my Autel code reader (see below)
  11. Issue does not fluctuate with engine temp, or fuel level
  12. Initiates from either start or mid-drive
  13. Issue did begin immediately after adding a string dose (2X) of PS Diesel Kleen; however, no such issue on a dozen prior additive additions (coincidence?)
20K miles since last transmission fluid service
Transmission, engine, and power delivery appear strong and healthy when issue is absent.
No codes indicating conductor plate/speed sensors; dealer suspects valve body, based on description (with $2500 estimate)
Codes, most stored:
B21 0113
P25567B
C220500
121500
184000
B1 DD01 5
U01 4786
U01 2986
B1 FBD04
U01 3287
Does this sound fairly cut and dry to anyone? Would there normally be a software intervention prior to physical repair? Any recommendations in diagnosing, hypothesis testing, or likely diagnoses are very much appreciated. –Michael
Old Sep 9, 2019 | 12:47 PM
chassis's Avatar
2017 GLE350 4MATIC
Labored and delayed shifting sound to me like an exhaust restriction. What condition is the bluetec system? DEF dispensing, DPF, EGR, NOx sensors?
Old Sep 9, 2019 | 01:13 PM
mijotu's Avatar
2004 MB E320 Wagon
To the best of my knowledge, all is well: AdBlue tank and pump were recently replaced, haven’t looked at EGR nor am I aware of NOx condition. Recently topped off tank with certified store brand DEF under the assumption that it is of an equivalent quality.
How might I go about checking the mentioned variables? Would the exhaust restriction still “reset” upon turning off the engine?
Old Sep 9, 2019 | 09:43 PM
geniushanbiao's Avatar
2012 ML350 Bluetec, 2015 GL350 Bluetec
I would first get a star or Xentry system hooked up and look for trouble codes, especially in the engine and transmission modules see if there's any info. This will give you idea whether it's an engine issue or transmission issue then you can start from there. If it's engine issue, see what the code tells you and perform appropriate work. The OM642 engine is known to be problematic if not maintained properly so that's not surprising. If it's a transmission issue, I would first check the fluid level and condition. If level is correct, drop the pan and cut open the filter see if you can find any metal particles in the pan and filter. If there is then the transmission is shot. If not, depending on the condition of the fluid, you can consider dropping the valve body and clean it thoroughly. After putting everything back you can perform a relearn of the transmission. This should solve the issue.
Old Sep 10, 2019 | 12:53 AM
mijotu's Avatar
2004 MB E320 Wagon
I agree that it is a good idea to be suspicious of code readers vs Xentry, but are the former always at least somewhat unreliable? My reader has been pretty faithful when comparing old service records to stored codes pulled. However, pretty faithful is just that...
The insinuation that my vehicle isn’t maintained aside 😆, during the past 20K miles since its last transmission service Raymond did at least once tow a light travel trailer. I did see the debris cleaned from the ports using a magnet in a video that I stumbled upon today — that module seems Iike something any dealer would benefit from replacing, rather than servicing, if for no other reason: orders issued at the MB corporate level.
This feels very encouraging, but I am no doubt open to additional points of view. Thank you, geniushanbiao!
PS How does one do a transmission relearn?
