Remove Dash Trim Pieces
Old Nov 24, 2019 | 12:27 AM
we47b1me's Avatar
'22 GLE 350 | '15 ML250 | '87 560SL | '19 GLC 300 | '12 C250 (sold) | '02 ML500 | '98 C230
Hi guys,
Does anyone happen to have the StarTek docs, or the ability to look up how to remove the wood trim pieces on the dash? I'm swapping out the big piece above the glove box and radio.
Thanks!
Old Nov 25, 2019 | 09:29 PM
chassis's Avatar
2017 GLE350 4MATIC
To remove the large trim piece in front of the passenger:
Remove climate control controls, starting by removing the bezel around the radio controls using wedge 110589035900, followed by two extraction hooks 140589023300 to release climate controls
Remove COMAND unit
Remove center air ducts using two (2) extraction hooks 140589023300
Remove right air duct using two extraction hooks
Use wedge 110589035900 to "unclip instrument panel trim piece from instrument panel".
Old Nov 25, 2019 | 11:36 PM
we47b1me's Avatar
Remove COMAND unit
Thank you!!!
Old Nov 10, 2020 | 06:59 AM
Ramaya's Avatar
ML350 BlueTech AMG-Line
Hello,
(Sorry tried to connect with you via message but wouldn't let me)
I've seen you've done an android screen conversion to your ML and see you got some extensive experience with it.
I want to do the same my main reason for doing so is to have Waze + Spotify and a little more functionality from the infotainment system.
My main issue is that I want to keep using the cars MIC/Speakers for phone calls rather than the inbuilt MIC of the android unit. Have you got any experience with that?
Unfortunately my options for a unit are limited since I'm based in the UK i have found a "reputable" supplier from China unfortunately that can provide me with a NTG 4.5/4.7 compatible unit with a 8.4" (I dont want to cover the vents) with car play included.
Old Nov 10, 2020 | 08:16 AM
we47b1me's Avatar
Originally Posted by Ramaya
Hello,
Easy. Don't pair your phone with the Android side, keep it paired with COMAND.
Old Nov 10, 2020 | 08:35 AM
Ramaya's Avatar
I take I can still tether it for internet purposes? Only thing will be I will have to switch to the original COMMAND if I want to make a call?
Old Nov 10, 2020 | 08:38 AM
we47b1me's Avatar
Yes on tether. Tether uses wifi (if you do it right). Tethering via BT is limited by speed of the technology.
You either switch back to the COMAND side, and dial in the phone app, or dial from your phone.
Old Nov 10, 2020 | 09:03 AM
Ramaya's Avatar
Fair enough, thanks for the info.
