Steering Gear Housing Bolt Recall
Old Nov 24, 2019 | 02:35 PM
Babukb2's Avatar
ML350
adding more info in regards to the recall mentioned here...
https://mbworld.org/forums/m-class-w...nt-recall.html
i received a recall letter from MB. Here are some details in case anyone needs to look into it for their car, i wont write out everything word for word but this should provide sufficient info...
TC Recall # 2018724
MB Recall# 2019070002
year 2011-2017 M class, GLE, GL, GLS, C, E, GLK, GLC, CLS, and S vehicles
"the aluminum bolts of the steering gear housing cover and of the power pack could corrode due to moisture intrusion in combination with extreme climatic conditions and aggressive road salting. over time, under corrosion-prone conditions, fracturing of weakened bolts cannot be ruled out. in the unlikely event that all three mounting bolts break over time, the power pack could separate from the steering gear. as a consequence, although unassisted steering capabilities would remain, the power steering would fail, which could increase the risk of a crash."
when i called my local dealer i was asked to call back in a month or so due to lack of parts to complete the work for this recall.
while i wait for my dealer to get the parts, id like to visually inspect the bolts and also keep an eye on them, but i have no clue where the bolts are.
Does anyone know which bolts this recall is referring to and have a link for a video or parts diagram that could guide me in ensuring I look over the right bolts?
Old Nov 24, 2019 | 04:56 PM
chassis's Avatar
2017 GLE350 4MATIC
https://www.wheels.ca/news/mercedes-...rust-problems/
No photos in the link above. Can you ask the dealer service advisor which bolts will be replaced?
Old Nov 24, 2019 | 05:39 PM
Babukb2's Avatar
ML350
the letter i got states
"a replacement of the steering gear housing bolts and the application of a corrosion protection coating to the gear housing or, if the bolts cannot be removed, a replacement of the steering gear itself."
how many bolts are there holding the steering gear housing? the letter stated "all three" so i assumed there were only 3 bolts holding the housing.
or do you mean try to get a part # for the bolts from them so we can maybe identify on a parts diagram?
Old Nov 24, 2019 | 07:37 PM
chassis's Avatar
2017 GLE350 4MATIC
I mean call the dealer and ask them your question.
Old Nov 24, 2019 | 08:08 PM
excal's Avatar
W166
So MB Canada doesn't think "copious amounts of road salt" are used in any other provinces besides the 5 mentioned in the article...
Old Nov 25, 2019 | 11:57 PM
Babukb2's Avatar
ML350
my guess is those provinces have harsher winters and tend to use more salt than the other provinces
i'd be curious if there are any statistics on that though
Old Dec 4, 2019 | 09:26 PM
vrmb's Avatar
2012 ML 350 (W166)
Just got snail mail from MB for this recall for my ML, I'm in Massachusetts, USA, will call to see if it needs to be done.
