Tire size for my 2014 ML350
Old Jan 13, 2020 | 03:52 PM
Dinesh Sharma's Avatar
ML350
Hi
Currently I have all season tires on my SUV 265/45R20 .
I am getting a good deal on winter tires with AMG rims but the size is 255/40R19 - would they work or are they recommended or are they too small. for a SUV
thanks
Old Jan 13, 2020 | 04:11 PM
Etienne Lau's Avatar
Ml350 bluetec
My 2014 ML 350 is stock with 255/40R19 tires and wheels. So size I would consider them just fine, but then do you have 19" rims to go with those 255/40R19?
Old Jan 13, 2020 | 04:14 PM
ML350
yes these come with AMG rims . So should be good? Do you have 255/40R19 for sure? can you double check? yours might be 255/50R19. Can you please check
thanks
Old Jan 13, 2020 | 04:35 PM
Ml350 bluetec
thanks
My bad I have 255/50R19 tires and rims. But if you have AMG rims the 255/40R19 will not fit those rims.....You still need new rims. If you install the 255/40R19, then likely your speedo will read wrong.
Tire Placard on door
Actual Tire size on tire
Old Jan 13, 2020 | 04:37 PM
ML350
I meant the tires are on the 19" AMG rims already. But not sure if 255/40R19 would be good for SUV or not
Old Jan 14, 2020 | 03:53 PM
Ml350 bluetec
Go here: https://tiresize.com/calculator/ and plug in your current tire/wheel combination and compare with your 19" AMG and see how big a circumference difference it will be. Mainly you might see a speedo reading wrong speed with the 19
Old Jan 14, 2020 | 04:03 PM
Ml350 bluetec
The other thing you need to look at is LOAD Rating. These are Heavy SUV, and need tires with at least XL Load capabiltiy. So that's something you need to consider beyond just the size. My opinion is you pass on these rims and tires. THE AMG for the SUV are 20" and not 19" rims.
Old Jan 14, 2020 | 05:31 PM
ML350
Thanks. I checked the offset, it was way different as well. So I passed on it. Those were tires off an S-Class sedan.
Old Jan 14, 2020 | 05:34 PM
Ml350 bluetec
Oh, yes definitely the tires would not have worked due to the weight differences between the S-Class and the ML-Class. The S-Class starts at 4500lbs and tops out at 5200lbs, while ML-Class starts at 4700lbs and tops out at 6000lbs. So on average depending on engine and options and nearly 1000lb difference.
Old Jan 15, 2020 | 01:22 AM
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
Er - perhaps you mean 255/50R19, not 255/40R19? No W166 ML ever came stock with 255/40R19. Thoise are indeed too small (sidewall height / diameter / circumference-wise) and probably don't have the load rating for an SUV.
