Headlight help
Old Mar 29, 2020 | 02:04 PM
Lecomte38's Avatar
ML 350
Headlight help
2014 ML350. Halogens horrible. I have read the threads. It looks like Morimoto XB 35 Elite HID System - H7 5500k - purchase from AZN Optics.
questions:
1 . Do I need 2 kits for high and low beams ?
2. Is it plug and go or do I need other components to make it compatible - no Light Out warnings?
3. Any problems for an old hammer mechanic to install?
4. Any opinions or reviews? Is better choice then LED?
thank you for your valued experience and thoughts
Old Mar 29, 2020 | 02:55 PM
AZN Optics's Avatar
SPONSOR/MBworld Guru
questions:
Straight from the source, but feel free to confirm with others..
We'd actually recommend our Hybrid HID conversion kit over the pure Morimoto kit on M/G class front SAM. Performance is better.
1. Yes, two kits, one for low, one for high.
2. Our kits are canbus pre-configured so will work with MBs.
3. Fairly simple DIY project and a common first DIY for most. As a mechanic you won't have any challenges.
4. I get the HID vs LED question all the time. Nothing against LEDs, but they are not optimized to function well in housing designed to capture and forward project 360 output halogen light spread. Due to LED point dispersion, you typically end up with reduced throw distance, dark spots, and light scatter. They can brute force be better than halogens, but HIDs will out perform as it has true 360 light output that the housing can better leverage.
Old Mar 30, 2020 | 02:37 AM
The Truth's Avatar
2015 S63 & 2014 ML350
Went with AZN Optics. Can't go wrong. They are perfect in my wife's 14 ML350.
Old Apr 1, 2020 | 08:33 PM
Lecomte38's Avatar
ML 350
Kits are on the way from AZN. Great person to deal with. Very helpful. Good price
