W166 Battery
I suspect the batter/batteries will be flat when i eventually get to recovery
The vehicles was lock with central locking
What issues have i got to deal with when i return to collect
I took the battery that would not start my 2014 model and plugged it into the battery charger, would not charge, as further evidence that your idea of killing alternator is just something you thought up. Reduced capacity is why it would not start and not a drained battery that as you suggest would kill alternators. Don't get me wrong, yes drained batteries do kill alternators, but a reduced capacity battery does not.
An alternator constantly trying to charge a reduced-capacity battery will be charging at close to, or at maximum capacity. The alternator creates heat while creating voltage and handling the subsequent amperage. Charging at maximum capacity all the time means that the alternator is running at high(er) temps.
But yeah, I'm sure you're prolly right...
Should I also change the auxiliary battery located in the trunk while I’m at it?
https://costco.interstatebatteries.c...287&Country=US
very helpful video. i imagine youve gone through this already, did you really have to take apart the trunk that much to get to the aux? is there no way to reach the battery from the side without taking off all the side panels? seems like such a PITA for something that couldve been a really quick fix.
also looking for battery recommendations (main & aux) as i should replace both of mine soon. still have the originals in my 2014. ive heard/read that these cars can be "sensitive" for batteries and crappy ones can cause odd electrical issues or warnings. so without splurging on the dealer batteries, id like to do my research and ensure i buy something i wont have problems with/will last as long as the oem. any recommendations would be helpful before i start shopping around.
Main battery should be an AGM type. Deka are good batteries, not sure if they make the W166 size in AGM. I am still on the factory batteries with a 2017 GLE 350.
