Replaced dead factory radio "Anti Theft Activated"
Old Jul 18, 2020 | 08:41 AM
rajah996's Avatar
CLK55, CL500, Q45
Question Replaced dead factory radio "Anti Theft Activated"
Hey guys,
The radio in my 2014 ML350 died, would only flash the "on" light and screen would not turn on.
Replaced the radio with one from another car, now it says "Anti Theft Activated - Service Required"
Does the new radio need to be coded to the car?
I have a Star, and can give a shot at coding it, if anyone knows how to do it, and can provide some instructions, that would be awesome!
Thanks in advance,
-R
Old Jul 20, 2020 | 10:29 PM
rajah996's Avatar
CLK55, CL500, Q45
So I used Vediamo to unlock the radio with the needed PIN.
Now the radio appears to work, however there is no sound. Xentry is showing a fault - Sound system not installed in new radio's MOST setting.
Anybody know how to change that coding?
Old Jul 22, 2020 | 04:22 PM
rajah996's Avatar
CLK55, CL500, Q45
Plutoe,
Thank you for the solution
I have DAS Xentry, although very limited experience, would you be able to help walk me thru it, or tell me the steps and i can figure it out? Thank you
Old Nov 26, 2024 | 09:29 PM
pahanorlando's Avatar
Did you ever figure it out?
I am still in the first step of this
Old Dec 25, 2024 | 08:21 PM
Just finished it through vediamo. On 2014, I could not connect using DAS xentry and using regular xentry did not give options to activate the radio.
Other small issue I had is backup camera did not work, I had to go through vediamo and change settings as new radio unit thought I had regular backup camera, but I had 360 camera system.
