4 matic transfercase main shaft seal
Subscribe
Aug 23, 2020 | 01:17 PM
2012 ML350BT, 120000km at clock. I have a oil leak between transmission and transfercase. It is NOT from the transfercase propellers seals, to me it seems to be te main transfercase inlet shaft seal😩😩 Is this common for this 4 matic suw? It is oil dripps at the downer bolts at the transfercase and at the area around the engine mount under transmission.
Reply 0
Aug 23, 2020 | 04:14 PM
Quote: 2012 ML350BT, 120000km at clock. I have a oil leak between transmission and transfercase. It is NOT from the transfercase propellers seals, to me it seems to be te main transfercase inlet shaft seal😩😩 Is this common for this 4 matic suw? It is oil dripps at the downer bolts at the transfercase and at the area around the engine mount under transmission.
@kkarb Can you post photos? What fluid is leaking? What color is it? Have you smelled it? Serious question. Engine oil, ATF and drivetrain (gear) oil have different smells.
Reply 0
Aug 24, 2020 | 01:51 AM
Quote: @kkarb Can you post photos? What fluid is leaking? What color is it? Have you smelled it? Serious question. Engine oil, ATF and drivetrain (gear) oil have different smells.
Hello, i just cleaned it up, but i took a photo before. No smell of the oil. Im pretty sure its from the transfercase. The first two pictures is taken in May this year, the last is taken yesterday.
Reply 0
Subscribe
Currently Active Users (1)
