Android 8.4" Display Installation (Information & Help)
My issue has to do with the resolution of the original NTG 4.5 system as the new screen does not seem to be readying it correctly. I am aware there is a setting you can select the correct version of the screen but until now I have not been able to find that said menu.
There is an excellent thread for the C Class W205 which I have been through but to not much result with regards to my issue.
Here are a few images from my install:
Original look.
Old screen out.
4G + GPS Antenas positioned under the dashboard space.
Test run.
Screen working ok, centre control buttons work.
The issue I have with the original NTG System resolution.
Cheers!
Original look.
Old screen out.
Test run.
Cheers!
Between the two installation videos below you will have everything you need to do the hardware installation:
https://bit.ly/3lgxhom
https://bit.ly/3fKG3JT
Also, did you have any issues with the static noise I referred to in my first post at all?
