2014 ML400 Electronic Problems
Old Mar 7, 2021 | 05:16 AM
DIGGER11's Avatar
ML400 2014 W166
Not sure what is going on here, but car has had no electronic problems until yesterday. I got all of these warning messages at some stage. Most disappeared within 5 or 10 seconds, others I had to stop and restart to reset.
-Remote Battery Flat ( it has a new battery and measures 3.1v)
- Pre safe functions disabled
- Distronic Inoperative
- Active lane keep assist disabled.
Seems strange I am getting so many error messages, that I suspect something else is going wrong. Main battery appears to be strong as it starts easily.
Any ideas ???
Digger
Old Mar 7, 2021 | 09:13 AM
chassis's Avatar
2017 GLE350 4MATIC
How old is the main battery?
Old Mar 11, 2021 | 02:05 AM
DIGGER11's Avatar
ML400 2014 W166
Good point on main battery, is original so 7 years old.
Resting it is sitting at 11.8v , running 14.4v.
I know suspect this might be the problem.
Old Mar 11, 2021 | 01:06 PM
chassis's Avatar
2017 GLE350 4MATIC
Replace the battery.
Old Mar 12, 2021 | 01:27 AM
DIGGER11's Avatar
ML400 2014 W166
So I replaced the a battery with a 850CCA AGM, as the battery was still the original - so it would have stopped working at some stage anyway.
Unfortunately, all of the error codes are still randomly appearing.
I plugged in my $10 OBD code reader, but it is useless - but it did show a OBD/ECU voltage of only 11.8v when engine is switched off. My multimeter measures 12.6v at the terminals under the hood - so I am now suspecting a voltage drop/drain somewhere.
Might need to go to mechanic, as I think is beyond my DIY abilities unfortunately.
