Life Gate Issue
Old Mar 8, 2021 | 02:42 AM
MecML's Avatar
ml320
Life Gate Issue
Hello all, I have a ML250 (W166). The automatic liftgate stopped functioning about a month ago. It will automatically unlatch (and latch) but the will not automatically lift or close. All the fuses are OK and the lift actuator is new. I have a position sensor on order. Any ideas of items I should check? Is there a relay in the system which I should check?
Thanks for any help.
Old Mar 8, 2021 | 02:45 AM
Zuffen's Avatar
2002 Ml320, 2012 ML350 & Slk55
I think it could be the gas strut has lost pressure and the lift arm isn't strong enough to raise the tail gate without that bit of assistance.
I've noticed my tailgate won't open sometimes on a hill and I think it's the gas strut as the tailgate works fine on the flat.
Old Mar 8, 2021 | 02:49 AM
MecML's Avatar
ml320
The strut on the driver's side is fine. The actuator is not getting power/signal on the passenger side. It is new (thought that was the issue and replaced it, but it is not). When push the remote button or door button or the rear hatch button/lever the auto latch unlatches the door, but the actuator does nothing... I can manually open an close the liftgate fine (and it stay up when open).
Old Mar 8, 2021 | 07:57 AM
gkgeiger's Avatar
'10 C300, '15 ML250BT, '22 M850i Vert
The dealer replaced my actuator a few months ago, I do have an extended warranty though.
Old Mar 8, 2021 | 12:43 PM
chassis's Avatar
2017 GLE350 4MATIC
Either replace the actuator or dig into the spare tire area to see if you have signs of water. W164 and some W166 models have been known to have water ingress in the spare tire area and it can cause electrical problems.
Old Mar 8, 2021 | 12:52 PM
MecML's Avatar
ml320
Actuator has been replaced, so that was not the issue. I reset the liftgate last night and it looks like that solved the problem. Thanks to all the folks who replied to this message.
Old Mar 10, 2021 | 12:42 AM
telrush's Avatar
2004 SL500 2015 ML350 Bluetec
Hi,
Can you explain how you reset the liftgate signal? I think I might have the same issue with my problem.
Best,
TJ
Old Mar 10, 2021 | 07:44 PM
OnlyGerman's Avatar
Too many german broads
Originally Posted by telrush
Hi,
Best,
TJ
Also interested in knowing this process
Old Jun 13, 2021 | 08:58 AM
pgolfco's Avatar
2020 AMG GTC, 2021 Lexus LC500 Convertible, 2020 GLE350 4Matic, 2005 Honda S2000, 2005 Jeep Wrangler
What is the process for "resetting" the lift gate?
Please advise.
Thank you,
Chris
Old Jun 13, 2021 | 04:43 PM
chassis's Avatar
2017 GLE350 4MATIC
Old Jun 19, 2021 | 12:03 PM
MB350ML's Avatar
2011 ML350, 2011 C300, 2005 C230 kompressor
I am having the same issue but it has both the lift arm and the gas strut new.
Old Dec 2, 2021 | 04:15 PM
L-L's Avatar
L-L
2015 GL350 Bluetec
MecML, Can you explain how you reset the liftgate?
Thank you
Old Dec 4, 2021 | 06:09 AM
hyibin's Avatar
E270 cdi W211, E350 cdi W212, ML350 BlueTec W166
Use Xentry to reset the tailgate unit.
