2012 ML 350
Old May 5, 2021 | 01:36 PM
The Pickle's Avatar
sl550
2012 ML 350
I wanted to find out if there is a fuse specifically for the rear left signal light. Mine is NOT working and I can’t find a diagram for the three fuses boxes for this year that would tell me if it has an individual fuse. The whole light assembly costs over $350 after market, therefore want to check all bases. Here is the light in question. LEDs are the failed component and when I peak inside housing, there is a circuit board.
This is the complete unit removed from vehicle
White led section is the left signal
Back of unit; this standard build is brake light bulb!
Old May 6, 2021 | 10:06 AM
OnlyGerman's Avatar
Too many german broads
Can be found for around 100 new on ebay
