NOX Sensor is same as Soot Particulate Sensor?
Old May 26, 2021 | 09:31 AM
titang9's Avatar
2013 ML350 DIESEL
Is the NOX sensor the same as Soot Particulate Sensor?
OBD code: 16CB00
Old May 26, 2021 | 01:37 PM
Etienne Lau's Avatar
Ml350 bluetec
Soot Particulate is part of the DPF system (Diesel Particulate is soot). NOX sensor is a separate system, that uses pre and post catalyst sensors to control how much DEF fluid to use to reduce the NOX emissions.
Old May 26, 2021 | 02:31 PM
titang9's Avatar
2013 ML350 DIESEL
Thanks, So, is code 16CB00 the NOX sensor or not?
Old May 26, 2021 | 04:45 PM
Ml350 bluetec
it's your DPF Soot sensor. Not the NOX sensor.
Old May 26, 2021 | 10:40 PM
titang9's Avatar
2013 ML350 DIESEL
I Can't find this part on any parts diagram. Please could you tell me the part number?
Old May 2, 2024 | 11:26 AM
Stoyan Stoyanov's Avatar
2014 ML W166 350 BlueTec
Do you know of I have to program or just plug and play with the soot sensor?
Old May 2, 2024 | 04:31 PM
titang9's Avatar
2013 ML350 DIESEL
No idea, the dealer repaired the problem. Don't know what they did.
