Low speed shudder / miss
Old Aug 20, 2021 | 05:13 PM
davidbr93's Avatar
ML 350
I have a 2014 ML 350 Bluetec with 100K miles that occasionally has a low speed shudder, almost like the engine is missing. It evens out and accelerates fine when you get on the gas. It also doesn't happen all the time. I'm thinking I'll do the normal air filter / fuel filter change, but was wondering if others have seen this issue. No check engine light / messages have been triggered. I have a iCarSoft MB II that I could possibly look for codes with.
Old Sep 23, 2021 | 01:40 PM
paulwith's Avatar
ml350amg slk 320
Have same model and year, same symptoms but only at 60-80 degrees engine temp. No problem when hot .Any ideas?
Old Sep 23, 2021 | 03:31 PM
chassis's Avatar
2017 GLE350 4MATIC
Shudder can be related to failing torque converter turbine vanes or lockup clutch. Do thorough diagnostic tests to see if it is combustion related or drivetrain related.
Also consider that engine or transmission mounts are the problem. Three diagnostic paths to go down.
If you have no CEL, that would downplay the combustion diagnostic path in favor of rubber mounts or torque converter.
Old Nov 3, 2021 | 07:14 PM
Etienne Lau's Avatar
Ml350 bluetec
Possible air leak pre turbo and post turbo. Check the large orange seal between the air filter housing and turbo inlet. Also check the seals on the turbo outlet as it connects to the aluminum pipe that routes to the black turbo muffler just before it feeds the intercooler.
Old Nov 8, 2021 | 10:57 PM
dacather's Avatar
2012 ML 350 BlueTEC, 2006 C280
I had something similar happening with ours. It didn’t happen all the time and but only seemed to happen at low pedal input, if you gave it gas it would accelerate smoothly. I cleaned all the gunk out of the intakes and EGR components while I was doing oil cooler seals and haven’t had the issue since. Can’t really prove it but I always thought our problem had to do with the swirl flaps wigging out since airflow was so restricted and that at higher RPM boost pressure would get rid of the problem.
