Part # for plastic retainer clip for front fender door to gain access to lo beam?
Can someone provide me with the part number for this clip? Thanks
is this the correct one?
https://www.fcpeuro.com/products/mer...vet-1249900492
i believe it is either #8 or #11 on that link. That flap may be just one whole assembly.
Ok thanks, does your clip have a center pin you pull out first? I don’t seem to see the particular clip on the parts diagram.
#8- front fender liner nut
#11- front fender liner cover
Like you said it might be just one assembly (the clip only comes with fender cover) but I findthat hard to believe since these clips easily break.
Update:
I called the dealer and they said they have the rivets for $3 each but they wouldn’t give me the part number - I guess they don’t want me to order them elsewhere. I looked at the parts diagram again and I think this is the correct rivet— can someone confirm this, if not can you post the correct part number?
Ft Fender Liner Rivet
124-990-04-92 Fender Liner Rivet, Left
I would order from the dealer one, and if it is not, return it. Now, once confirmed you can order a few from China, say AliExpress and keep them in your garage. It is similar to the one for the radiator reservoir, correct? And many other uses
I appreciate your reply, ok I will swing by the dealer this weekend and purchase the rivet . Thanks
