2014 ML350 left headlight ground fault
is that the correct fuse? I do not have a diagram.
if it is there is 12v at the fuse.
where does the ground end up so I can check that.
any help welcome
Anyhoiw, if anyone has experience headlight shorts on ML350 then I would like to hear them.
VIN
miles
how long you have owned it
modifications on the vehicle
symptoms/why do you think there is a problem?
VIN 4JGDA2EB3EA397804
the drivers side headlight stopped working with the code registering a short to ground . I had it diagnosed at the dealership and it is a fault in the wiring inside the headlight and a bad control module.
They did not charge me much for the diagnosis considering they had the whole of the front to of the car off. However their quote to fix it - replace the headlight and the control module is close to 5K - ugh.
I have an independent mechanic who is sourcing parts for me to reduce the price. I have found a headlight unit for less than $1000. Are the aftermarket parts any good. Can the headlight be fixed?
What would people do not to spend 5K?
