Reaching back bolts on ML350 Engine Cover?
The 2 bolts at the back are down in the 2 holes that you see at the back. Just need a long extension to reach it. If you have a magnet, will be helpful to pickup the bolts and when putting them back in. Just loosen then all the way, slowly remove your socket and then with the magnet pick them both up. This will ensure that the bolts don't fall out when lifting the intake off. Reverse to install.
