2014 w166 front lower control arm rear bushing removal
Subscribe
Oct 29, 2021 | 10:05 PM
Trying to replace the bushing but there doesn't seem to be a way to remove the nut that attaches the bushing to the control arm... just a flat round covering... videos shows a nut but mine is different.. is it pressed in?
I already removed the 2 bolts to the frame
Reply 0
Oct 29, 2021 | 11:24 PM
Do some searching on this site, pretty sure the LCA is replaced as an assembly including the bushing.
Reply 1
Apr 2, 2023 | 05:33 PM
Did you ever figure out the solution? Did you need to remove the entire LCA and press
Quote: Trying to replace the bushing but there doesn't seem to be a way to remove the nut that attaches the bushing to the control arm... just a flat round covering... videos shows a nut but mine is different.. is it pressed in?
Hi, I am working on replacing the same part. Was the solution to remove the entire LCA and press out the bushing? I bought the OEM MB bushing replacement, so surely there should be a way to replace it without replacing the entire LCA units? Thanks for the help.
Reply 0
Apr 2, 2023 | 05:38 PM
Quote: Hi, I am working on replacing the same part. Was the solution to remove the entire LCA and press out the bushing? I bought the OEM MB bushing replacement, so surely there should be a way to replace it without replacing the entire LCA units? Thanks for the help.
you replace everything.. its not removable
Reply 1
Apr 4, 2023 | 03:58 PM
for what i see these bushings are replaceable, but you'll spend more in tools than the whole arm..
Reply 2
Apr 4, 2023 | 04:04 PM
Thanks, appreciate the feedback.
Reply 1
Feb 6, 2025 | 04:59 PM
Quote: for what i see these bushings are replaceable, but you'll spend more in tools than the whole arm..
Thank you! Has anyone done it on a bench press? Is it doable? Or requirement is some specialty tool from Mercedes?
Reply 0
Subscribe
Currently Active Users (1)
