P24A5 code on a ML2013 Bluetec
Old Nov 6, 2021 | 09:08 PM
guibaco59's Avatar
ML 350 Bluetec 2013
First post.
I have been getting a check engine light with code P24A5 (read on my phone from a cheap obd2 scanner).
when I reset the light, I can usually drive a few days before it comes back. Done this 3 times already.
code description says:
P24A5 Mercedes-Benz Exhaust Gas Recirculation (EGR) Cooler Bypass Control Stuck (Bank 1)
any clue if this is the egr valve or something else ?
The car runs fine with no symptoms or lack of power.
thanks for your support.
Old Nov 7, 2021 | 01:24 PM
guibaco59's Avatar
ML 350 Bluetec 2013
Hi, any clues anyone ?
Old Nov 8, 2021 | 10:42 PM
dacather's Avatar
2012 ML 350 BlueTEC, 2006 C280
It sounds like the code is referring to the EGR cooler bypass valve located on the front of the engine (passenger side in US). If you look up a picture of an OM642.826 engine from the front, look for the two bent stainless steel pipes about in the middle, those are the two pipes going from the EGR cooler to the bypass valve. Recommend reading this about cleaning that assembly:
https://mbworld.org/forums/diesel-fo...-cleaning.html
EGR gasses can foul everything downstream of the cooler pretty impressively, including the bypass valve. Sounds like this could be related. Could also be something else besides actual fouling. My wife’s 2012 ML350 BT had a code for the EGR cooler bypass valve the other month (don’t remember if it was this one) and it ended up being a few holes in the vacuum hoses going to the valve. So when the valve was commanded to actuate, nothing would happen.
Hope this points you in the right direction.
Old Nov 8, 2021 | 11:04 PM
guibaco59's Avatar
ML 350 Bluetec 2013
Many thanks for taking the time to write this explanation
will start with a thorough inspection next week end and keep this thread updated.
Old Nov 16, 2021 | 01:54 PM
guibaco59's Avatar
ML 350 Bluetec 2013
The issue was a cracked vacuum line on the EGR switching valve solenoid. Fixed now and code has been reset.
Old Jul 22, 2025 | 07:56 PM
Potrice's Avatar
2013 ML350 Bluetec, 1966 Ford Mustang Convertible (sold)
Reviving this old thread. I'm getting the same code but with P245B. Can someone show me where this EGR switching valve solenoid is located (a previous user said near front end passenger side) or some instructions on how to remove it? I'll take a look at the vacuum lines. The CEL is on and the suv seems to run fine (2013 ML350 Bluetec 352 000 km) but fuel consumption has increased quite a bit.
Old Jul 24, 2025 | 06:58 AM
Potrice's Avatar
Quick reply! After inspecting throughly every vacuum line, I noticed one was loose and cracked. I repaired the vacuum line and erased the code. I will update if the code returns.
Currently Active Users Viewing This Thread: 2 (0 members and 2 guests)
