OM642 EGR/intake cleaning
Old Nov 28, 2017 | 12:32 PM
GoodByeHonda's Avatar
W211 E320 Diesel OM642
Looks like MB came out with a bulletin advising service to clean the short Egr pipe(front of the engine refered to as egr admission hose) every 40k miles. What I'm looking for is a way to tap into the intake system of a running engine (so without taking it apart) that I could spray in the cleaner at a pressure which would end up as a nice gush of a mist.
Has any one done it? What's the ideal spot to tap in? Ideally I'd like to get rid of the EGR system as I see it as the main culprit of diesel engine problems but for now, I'll remove the egr admission pipe and clean it following with a spray of the cleaner.
Old Dec 1, 2017 | 08:31 AM
skdjfsdf's Avatar
Beaters 'til they die
Interesting. Do you happen to have a link to this service bulletin?
Old Dec 4, 2017 | 02:57 PM
Sadly I don't. I was tipped off by a mechanic on my recent visit to get my alignment. I have tried to find it in my old eBay copy of WIS. I have also called my Indy shop and the guy said:"Son, this isn't a library, we fix cars here!". I had a good chuckle.
Old Dec 4, 2017 | 04:26 PM
Old Dec 5, 2017 | 09:33 AM
DanD.'s Avatar
2018 GLC 4MATIC
Can you take a picture of EGR admission pipe?
Im not sure which one is that.
And provide some info how to remove and what to use for cleaning.
Im not super mechanic but trying to take care of my ML.
Thank you.
Old Dec 5, 2017 | 08:40 PM
When you remove the 3 bolts, it just pulls off. Clean it with brake cleaner, throttle body cleaner or acetone or whatever you got. Torque is 15N.m on those bolts to reimstall.
here's some pictures off the net...
Old Dec 6, 2017 | 03:44 PM
DanD.'s Avatar
2018 GLC 4MATIC
Thank you GoodBuyHonda,
Just to confirm Im looking at the right pipe,
Please see attached picture.
Do I need to take anything else off ?
OM642 EGR/intake cleaning-photo706.jpg
Old Dec 6, 2017 | 04:18 PM
I'm not sure! Your motor setup looks different than my E 320. Perhaps other members can help?
I should add that the pipe you're pointing out looks like that's the one but it's so much more thicker than on an E class OM642. At least that's what I can see from your picture.
Old Dec 6, 2017 | 05:34 PM
DanD.'s Avatar
2018 GLC 4MATIC
I have 2014 ML 350 BT. OM642 engine and body W166. I thought engines are the same.
Old Dec 8, 2017 | 11:25 PM
Perhaps long block is but with time some things changed. Here is instructions on how to use Liqui Moly product.
Old Jan 20, 2018 | 07:20 PM
Shizzell's Avatar
2008 ML 320 CDI
GoodByeHonda, is the EGR pipe bolted inside of the engine (underneath those other pipes)? I see the 3 bolts on the front of the engine, is that the only thing holding that pipe in place? Thanks
Old Jan 22, 2018 | 08:46 AM
Correct. Have a look at my post from Dec 5. Make sure you replace the two gaskets. Have a peak at the image.
Old Jan 22, 2018 | 09:30 AM
Shizzell's Avatar
2008 ML 320 CDI
I'm sorry, but which of my previous questions is correct?
- The pipe has bolts on each side of the pipe
- The pipe is only bolted down with those three in the front?
If the pipe is bolted down on the inside of the engine, below the other pipes, is it possible to remove it without removing those other pipes?
Additionally, do you have the part numbers for those gaskets?
Thanks for your help
Old May 21, 2018 | 07:57 PM
babaz's Avatar
2012 ML 350 Bluetec
DanD I have the same gen w166 with the Bluetec motor. Did you find out if the picture you shared is the correct tube to remove and clean? Wondering how difficult it is to remove the tube.
Old May 21, 2018 | 08:06 PM
DanD.'s Avatar
2018 GLC 4MATIC
Sorry, I don't have an answer for you. Im planning to take another look when will be working on fuel filter. A lot of things must to come off and I should be able to see it better.
On the side note: EGR valve it on another side, by the firewall. So maybe the right pipe is over there. No so sure.
Old May 21, 2018 | 08:26 PM
With w211 E320, it may be possible to remove just the egr pipe but have a look at my throttle body pipe. I had a solid 3mm of deposits from the egr pipe arrachement point to intake manifolds. I cleaned intake manifolds as much as I could reach and got all the loose pieces out.
I replaced all the gaskets, even the throtte body gaskets on each side.
fyi, you can use 8mm socket for E8 bolts. That's ONLY if you don't have a tall E set. (You'll need it for the left side 2 bolts that attach the pipe to the bracket)
looking at the state of my intakes, I should have just changed the oil cooler gasket. But it seems that we can utilize the muffler port to spray in Liqui Moly cleaner.
will work on adapter soon....
Old May 21, 2018 | 11:48 PM
kajtek1's Avatar
1922 Ford Model T / no OBD
Seems the deposits come in different strength on different engines. Here is the best picture I have of it from my 180,000 miles engine.
The deposit are definitely here, but others have more of them at 120k. My car drove 160k in TN and 20k in CA.
Old May 22, 2018 | 01:37 AM
Suprdave's Avatar
2011 R350 Bluetec
I have a code for sticky EGR...that's 20k Miles after Mercedes had to torch it off and replace one under warranty and clean it...
My plan is Hydrogen Carbon Cleaning...for an Hr...which is like Double time...then I'm going to add a Pre-Turbo Water-Meth in the future...and get a catch can for the PCV system.
That should keep it pretty clean after that...I'll report back ina week or 2 with the hydrogen cleaning results.
Old May 22, 2018 | 01:49 AM
Suprdave's Avatar
2011 R350 Bluetec
Actually I have 71k and Merc last serviced (****ty) at 55k...so thats basically 20k...I'm gonna get this and the tensioner issue handled this week. Afterwards I'm gonna start doing Carbon Cleaning every 5k Oil change with Redline 20w-50 and Ceratec. This **** is going 300k or it's going into the ocean...
Old May 22, 2018 | 07:19 PM
peter2772000's Avatar
2012 X6 35i Sport, 2013 ML 350 BT, 2019 4Runner TRD Pro, 2020 CRV-AWD
Funny, I just received an email today from Mr Stephen himself, along with two attachments for the intake/EGR cleaner.
File Type: pdf
Old May 22, 2018 | 10:45 PM
DanD.'s Avatar
2018 GLC 4MATIC
+1. Like to know all answers especially part numbers.
Old May 22, 2018 | 11:18 PM
DanD.'s Avatar
2018 GLC 4MATIC
Originally Posted by peter2772000
Funny, I just an email today from Mr Stephen himself, along with two attachments for the intake/EGR cleaner.
I wish Mr Stephen could explain how to use this?
Old May 23, 2018 | 04:05 AM
Stoopid simple.
https://www.youtube.com/results?sear....20+EGR+Coking
Sorry, he'd included that in the email.
Old May 23, 2018 | 04:30 AM
Great post and awesome pics, thx.
The below may help you:
"Mercedes has now started to recommend the EGR valve be cleaned every 40000 miles. Burnt oil clogs it. We found a way to really clean the EGR & the rest of the emission system. We took the Liqui Moly kit for cleaning the DPF, & modified it. We remove the sensor in the EGR pipe. We made an adapter that threads into the EGR pipe & connect it to the Liqui Moly gun in their DPF cleaning tool. We put BG 245 diesel fuel system cleaner into the gun & spray the BG 245 cleaner straight into the EGR pipe as the engine is running. The BG 245 really cuts through the crud in the EGR system & it cleans the DPF at the same time. The whole system is getting a serious cleaning. This is simple, once you make up all the adapters to make it work."
Old May 23, 2018 | 07:15 AM
Which sensor is he taking about?
