Help with CAN communication
Old Jan 9, 2022 | 09:30 AM
mirinex's Avatar
2012 ML350 4Matic
Hello to all - I am working on a 2012 ML350 and the car was towed to me as a non start, non driving. The car has power all lights are working, windows, power seats, rear door and Radio. The wipers don't work, hated seats don't work and the car is not cranking and starting up. There we a bunch of codes present (the car was at another garage), so i decided to erase everything and start with whatever comes back. Here is a list all fault that come back right away.
IN ME i have:
U010182 No communication with TCM message is lost
U010387 No communication with ESM message is lost
In ESP module:
C085100 -variant of coding transmitted via CAN bus by N73- EIS/EZS is implausible.
Park distance control:
U042300 - Data from Instrument Cluster is implausible
U041500 - Data from ESP module is implausible.
U010100 - Communication with TCM is faulty.
Back up camera:
U010187 Communication with TCM is faulty
ARS (rolling):
U010000 - Communication with ECM is faulty
U041500 - Data from ESP is implausible.
I did some testing and looking around the car and all fuses and relays are good. Both Batteries were just replaced. The Main is Die Hard Platinum and the Aux is OEM. Resistance on pin 6 and 14 with battery disconnected is 60 ohms. with battery connected is 158 ohms - which is odd when power is present. Also voltage on pin 6 is 2.5 -2.52 volts and pin 14 is 2.38- 2.4 volts. I did an EIS/EZS test and the switch is responding OK on terminal 50. I have been reading/searching a lot and can not find anything. If anyone can shed some light with a similar problem would be greatly appreciated.
Old Mar 19, 2023 | 08:53 AM
jasonT1984's Avatar
2012 Mercedes Ml350
2012 Mercedes ml350
Hey i have a 2012 mercedes Ml350 thants doing the exact as yours. Did you ever figure it out?
Old Mar 20, 2023 | 09:11 AM
mirinex's Avatar
2012 ML350 4Matic
yes I did after $1,500 - turned out that someone did cross jump the battery terminals and blew a fuse that I did not know about - 150am fuse that supplied all power to all modules
Old Mar 28, 2023 | 11:06 AM
ForeignGuy's Avatar
2012 Mercedes Ml350
Hey which fuse is it and where is it located? my car is doing the exact same thing.
Old Mar 28, 2023 | 01:18 PM
mirinex's Avatar
2012 ML350 4Matic
it is on the left side of the engine bay next to the fuse box
Old Aug 18, 2023 | 08:17 PM
Unclewayne.cla's Avatar
Ml350 w164
Do you have a pic of it
Old Aug 19, 2023 | 12:22 PM
mirinex's Avatar
2012 ML350 4Matic
you can only see the 100amp fuse on the picture, but next to it is another 150amp
Old Jan 27, 2024 | 07:41 PM
Sulaco's Avatar
1999 C43 AMG, 2005 E55 Wagon
Helping a friend whose 2014 is doing all the same things. Lots of similar codes. Was this fuse easy to access and replace?
Old Jan 31, 2024 | 11:34 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
SCAN!
Can you get the vehicle scanned to retrieve faults??
CAN's can be disrupted by a whole lot more than a bad fuse.
