Need stock wheels for summer set
Old Feb 2, 2022 | 12:16 PM
W203fanatic's Avatar
2012 ML350 Gas
So I need to get a second set of wheels since the one I currently have is a Winter set.
I don't need anything oversized, staggered, low profile, stretched, etc. Just need a 19" original setup.
Are there any other models such as the GL, GLE, GLK, W164 which are a direct fit as long as they are the same 255/50/R19 size? How important is it matching the offset?
Do these vehicles require an alignment or some airmatic calibration if the wheels are switched?
Thank you and yes i've searched and couldn't find any relevant info.
Old Feb 2, 2022 | 12:24 PM
Isawelvis's Avatar
Veteran: Air Force
, 2023 BMW X4, 1991 190E
Any 166 from 2012-2019 Ml/GLE/GL 19 inch will fit for sure. Not sure about W164 or GLKs.
Old Feb 2, 2022 | 04:15 PM
2012 ML350 Gas
I also found an 8JX19H2 ET60 ? Any idea if this will work? Looks like Genuine Mercedes however looks like the W164 wheels.
Old Feb 5, 2022 | 07:02 AM
Doubleredrolex's Avatar
2014 ML550 AMG package
et60 is pretty sucked in. The smaller the number the further out it will be. The et60 should work as long as it clears your front brake caliber. If you have an ML550 then they probably won’t fit as it has larger front brakes than the ML350. Actually I just looked and my Ml550 comes with 20x9 et57 so you should be fine with those wheels if you have an ML350
Old Feb 5, 2022 | 07:04 AM
w164 wheels should be fine as long as the are 19” or larger.
Old Feb 14, 2022 | 06:34 PM
shotgun_banjo's Avatar
'13 GLK350 4matic,'10 C207,'15 GLA250,'07 Honda Odyssey, '18 GLE 43, '24 EQS 580
20" GLK rims with ET45 will fit (get the AMG ones). Why do I know? I tried it. The GLK rims are just 8.5" wide and will work with the stock tires of the W166. I find it actually better looking as it is not stretched at all more of square with a little bulge. The best thing is that it pushes out the wheels which gives it a more flush look on the fenders.
