2014 ML550 stalled at red light, will not turn over. No codes
Old May 13, 2022 | 04:39 PM
Feltcycle's Avatar
2014 ML550
My 2014 ML550 (115,000 miles) stalled at a red light today and when I went to restart it would not turn over. Event did not throw any codes. It sounds like the starter is engaging, but I’m not certain. Put a jump box on the battery just to make sure that wasn’t the problem and it made no difference. The car has been having some long starts recently and it did throw a code once for low fuel pressure. I could see this being the reason the car stalled, but it should turn over on subsequent restart. Hoping the engine isn’t seized. Any idea of what could cause this other than internal engine failure?
Old May 13, 2022 | 07:15 PM
chassis's Avatar
2017 GLE350 4MATIC
Replace both batteries and report back.
Old May 13, 2022 | 07:20 PM
Feltcycle's Avatar
2014 ML550
I replaced the main battery under passenger seat 2 weeks ago. Do you think the auxiliary battery could cause this?
Old May 13, 2022 | 10:28 PM
chassis's Avatar
2017 GLE350 4MATIC
Not sure. On a 9 or 10 year old vehicle, depending on build date, all batteries should be assumed to be kaput.
Safest choice is to replace it and see what happens.
Old May 13, 2022 | 10:39 PM
E55Greasemonkey's Avatar
This place is a joke.
Well, my first thought is a seized engine. Get a ratchet on the crank pulley bolt and see if it will turn by hand.
Old May 13, 2022 | 10:52 PM
Feltcycle's Avatar
2014 ML550
Yeah. Symptoms + no codes worry me. I’ll report back on Monday with results (working the weekend). My first plan of action was to try to turn engine over by hand. 🤞
Old May 13, 2022 | 10:57 PM
Unfortunately these twin turbo V8's are not ageing gracefully. Good luck, let us know...
Old May 13, 2022 | 10:59 PM
Feltcycle's Avatar
2014 ML550
I will check both main (new) and aux battery voltages Monday. Hopefully one of them is the culprit.
Old May 13, 2022 | 11:14 PM
Feltcycle's Avatar
2014 ML550
That’s a fact!!!
Old May 29, 2022 | 12:49 PM
jimmysanjuan's Avatar
2023 GLE 53
Any updates on what caused this problem?
