ML sounds like it has aluminum cans in the engine on startup
Old Jul 22, 2022 | 10:12 AM
JD101b's Avatar
2015 SL550, 2017 GLS 550, 2010 G550, 1995 E320 Cabriolet
My 2015 ML has about 95,000 miles on it. Recently, when I start it up, there is a large hollow rattling sound in the engine for about 5-10 seconds before the engine returns to a normal sound. There are no error codes presently. Any idea what might be causing this?
Old Jul 22, 2022 | 10:50 AM
chassis's Avatar
2017 GLE350 4MATIC
Gasoline V6? Could be chain tensioners that are lacking check valves. Read about this on the site for affected engines.
Or could be normal direct injection sounds. Are you familiar with direct injection engines/cars?
Old Jul 22, 2022 | 11:01 AM
JD101b's Avatar
I am. My concern is that this is a recent event. I've never heard these sounds before.
Old Jul 22, 2022 | 03:56 PM
chassis's Avatar
2017 GLE350 4MATIC
Gasoline V6?
Read through the chain tensioner check valve threads to see if your engine is in the affected range and if the work has been done on your engine.
Old Jul 22, 2022 | 04:03 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
https://static.nhtsa.gov/odi/tsbs/20...70532-9999.pdf
and,
https://tuningpro.co/the-4-most-comm...gine-problems/
or if interested in how it is done
