Ml350 performance
Old Nov 27, 2022 | 02:11 PM
FloriFlori's Avatar
Ml350 2014
Ml350 performance
I have a ml350 2014 4 matic and in my driving permit it says that it has 225kw convert to 306 hp. Can it be true ?
Old Nov 27, 2022 | 03:57 PM
chassis's Avatar
2017 GLE350 4MATIC
Yes. https://en.wikipedia.org/wiki/Mercedes-Benz_GLE
Old Nov 27, 2022 | 04:06 PM
FloriFlori's Avatar
Ml350 2014
But she is a diesel version
Old Nov 27, 2022 | 05:43 PM
Issac2021's Avatar
ML350
Mercedes Benz W166 Class ML 350 BlueTEC 4MATIC Engine Technical Data
Engine type - Number of cylinders : V 6
Engine Code : OM642
Fuel type : Diesel
Fuel System : Direct Injection.
Engine Cooling :
Engine Alignment : Longitudinal
Engine Position : Front
Engine size - Displacement - Engine capacity : 182.3 cu-in / 2987 cm3
Bore x Stroke : 3.27 x 3.62 inches
83.0 x 92.0 mm
Number of valves : 24 Valves
Aspiration : Turbo (TGV) + Intercooler
Compression Ratio : 16
Maximum power - Output - Horsepower : 254 HP / 258 PS / 190 kW
@ 3600 rpm
Maximum torque : 457 lb-ft / 620 Nm
@ 1600-2400 rpm
Drive wheels - Traction - Drivetrain : AWD
Transmission Gearbox - Number of speeds : 7 speed Automatic
Clutch Type : Torque Converter
Old Nov 27, 2022 | 07:20 PM
chassis's Avatar
2017 GLE350 4MATIC
Where did you quote the 225kW from?
Old Nov 27, 2022 | 07:42 PM
Issac2021's Avatar
ML350
225kw 306hp is gas edition but not diesel.
Old Nov 28, 2022 | 01:47 AM
FloriFlori's Avatar
Ml350 2014
I got 225 kw on my driving license
Old Nov 28, 2022 | 09:47 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
On your driver's license?? Where are you? Are you in a country that has tiers of licensing that limits the power you are allowed to drive?
Old Nov 29, 2022 | 03:32 AM
FloriFlori's Avatar
Ml350 2014
I live on albania and no we dont have limits on horsepower. I have seen some ml350 on sale with 225 kw diesel car , but it were so few of them
Old Dec 11, 2022 | 09:07 PM
C280 Sport's Avatar
MB’s of all kinds.
The V6 gas engine is the 3.5 V6 with 302 bhp. Move’s enough and hauls enough.
