Replacing speedometer from MPH to KM
My recommendation would be to research the Virginize process and then wait till you get to Europe to find a used speedo, since they all would be KM or check for a Canadian model. Good luck.
A much simpler and cheaper option would be to purchase a decal in km/h that you can apply over the speedometer dial. You're not tinkering with the odometer (which by definition would be put on the permanent record for the VIN) and not changing anything from an operational standpoint.
https://www.aliexpress.com/item/1005003141107410.html
https://www.aliexpress.com/i/1005001278507464.html
https://www.gshgbooks.com/index.php?...ucts_id=235763
