SRS warning light ML350 W166 2014
It's been a few days that this error popped up for some reason and I've tried several ways to delete it but to no avail.
One of the actions was to install a replacement SRS sensor in order to bypass the system but the error did not disappear and returned. And I also tried to delete it through the XENTRY PASSTHRU system, but also without success and the system did not give an option to reset this error. I tried to do a RESET for each SRS but the error keeps repeating itself.
How can I clear this error? And what could be the problem?
In addition, I checked the cables and there is no particular problem with the cables to connect the sensor.
The car is a 2014 ML350 W166.
Thanks.
* Attached is a picture of the error.
