Not Your Mother's ML550(Photo Dump, Build Thread)
Hey everyone! I figured it was time for me to make a build thread for my 2013 ML550.
I'm quite a ways in already but here's some pics with a short story up to where I am at now.
To keep a long story and a quick journey short I purchased the car completely stock about a year and a half ago(I have an issue keeping things stock lol). Not too long after, I pulled that massive muffler off the back and had the car tuned. It was fast, but not fast enough.
Fast forward a short while later, and I pulled the trigger on a transmission tune, and a WMI/ASV kit from Weistec along with a retune, along with air some DIY air filter spaces, air filters, and colder plugs. Also, I had replaced the torn cloth intakes with 3in silicon tubes from Amazon that I cut to fit. Wow, it was quick!
But, I still wanted more. Fast forward again, and I purchased valvetronic mufflers, then after that a while later again, I started experimenting. Come to find out, E20 Runs really well without a tune and the car felt a bit better with it. On top of adding some 3D printed air intake tubes to work with some cone filters, added in an ethanol sensor, added 3D printed a pod to fit in the dash for my guages, then got retuned with TunedMercedes on E40, and split the cooling system. That really brought the car to a whole new level right there.
At that point, my fuel pump I assumed was getting weak, or just was not keeping up, so I swapped it out for a new pump(come to find out the ML63 and the ML550 have the exact same part numbers) and with some magic, my ML550 is flowing at ML63 specs.
Currently where I sit, the pump is not keeping up at WOT in the mid/high RPM range, so more experimenting to come! In the mail is a Radium fuel surge tank, then hopefully I can get other parts ordered here soon like the lines and fittings, an AEM Stealth pump, some wiring, and a fuel pressure regulator.
The following 2 users liked this post by Wes1311:
BlackML550 (04-20-2023),
OnlyGerman (04-30-2023)
2013 ML350 Bluetec
Cool build, but honest question:
What is the benefit of pulling in hot air from the engine compartment rather than cold air ramming into the front of the car?
Are you seeing a fuel pressure drop at WOT at mid/upper rpm's on gauges?
The following 2 users liked this post by rapidoxidation:
AllPhonesAretap (04-12-2023),
I do have turbo blankets and I also plan on wrapping the bridge pipes and exhaust manifold to keep temps down, but I'll do that when the turbos are out at some point. I should see an increase in turbo spool efficiency doing that though probably not enough to matter.
I do see a massive drop in fuel pressure, but I am suspecting a HPFP is finally wearing out(128k miles on the motor now). I originally thought it was the in-tank pump so I changed it out. Oh well, at least I know the in-tank pump is good now
rapidoxidation (04-05-2023)
Thanks! I've never taken it on a dyno, but on my previous tune HPT was telling me about 750tq(crank I assume) and based on nerd math and 1/4 mile times 545(ish)hp. The current tune is far more aggressive now and feels significantly faster. If I had to guess, somewhere between 6 and 700 still but maybe the high end of 600. and maybe high 700's tq? The power delivery is far more smooth as well. But next time I get to the track, I should be at around a 1.8sec 60ft and an 11.9sec 1/4 mile. on the previous tune, those were the numbers I was told to expect from the previous tuner and I ended up doing a 2.0 60ft and a 12.7 1/4 mile, but the current tuner also fixed quite a few things that looked pretty generic and copy paste while retuning for E40 at the same time.
