replace brake fluid on 2015 ML 350
Old Apr 19, 2023 | 10:12 AM
frank94's Avatar
2015 Mercedes-Benz ML 350
Good morning,
My 2015 ML 350 has 45K miles, I am thinking it is time for overdue brake fluid replace myself. Does anyone has any recommendations? I am thinking to buy Motive bleeder method without use press brake method, but I do not know what be ok with SBC-Sensotronic Brake Control by use this method? any ideas?
THanks
Frank
Old Apr 19, 2023 | 02:36 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
There is no SBC on the 2015 ML as far as I know unless you are referring to something else, and you are overdue on your brake fluid replacement: it is @20K miles, or every other year to prevent moisture accumulation.
Here is a link describing the system, and which vehicles used it
https://en.wikipedia.org/wiki/Sensotronic_Brake_Control
Perhaps you are referring to the PreSafe Brake Assist system that came after the SBC debacle on the E-Class
Old Apr 19, 2023 | 02:52 PM
chassis's Avatar
2017 GLE350 4MATIC
Originally Posted by frank94
Good morning,
THanks
Frank
Read the DIY in my signature and in the GLE W166 section. Easy procedure. Just did it last night on my Porsche, same procedure also for BMW.
Old Apr 19, 2023 | 06:01 PM
frank94's Avatar
Thanks, How much brake fluid I need? one Liter should be ok?
Frank
Old Apr 19, 2023 | 10:05 PM
chassis's Avatar
2017 GLE350 4MATIC
Frank
I did my Cayenne last night with less than 1 liter, same size vehicle as the ML/GLE. I could have done my GLE with 1 liter but I always had an extra liter on hand.
If you are familiar with the process and know how to use the pressure bleeder, 1 liter is enough. Buy 2 liters and you will have an extra bottle as backup. If you don't use the second bottle (keep it sealed), you can use it for the next brake fluid replacement job in 2 years.
Old Apr 20, 2023 | 05:59 AM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
1 litre will be enough. I've always had another bottle on hand just in case I underestimate how much I've bleed out but never had to use it. I like to really flush it each time so you should be good to go.
Old Apr 26, 2023 | 11:59 AM
frank94's Avatar
I was prepared to get front and real brake pad, and brake fluid from fceuro, I read all the information about brake fluid replace and brake pad replace here. now I am ready to do this two jobs in one, so wonder what steps do I need to follow:
1. get ready to get some brake fluid out of brake fluid tank and add new fluid, and then add the rest of fluid to Motive Products, European Power Brake Bleeder, and then connect to the fluid tank.
to remove the passenger side real tire, and now I am not sure, do I need go to the console to retracting Electronic brake pads caliper,, replace real pad first and then do remove the old fluid? or remove brake fluid first and then go to console to retracting Electronic brake pads caliper,, replace real pad?
Frank
Old Apr 26, 2023 | 08:38 PM
chassis's Avatar
2017 GLE350 4MATIC
Read the WIS procedures in the DIY link in my signature. There are many, many posts on this site about replacing brake pads, rotors and fluid.
