Help With OEM versus OES Parts
Old Apr 22, 2023 | 06:02 PM
eddieo45's Avatar
me: 2015 SL400 & 2015 ML400; wife: 2022 GLC Coupe; daughter: 2017 GLC SUV
Originally Posted by musicmafia
So I've been trying to order the Akebono Euro pad kits online since yesterday and the part numbers are confusing.
F and R are:
EUR1629
EUR1629A
EUR1630
EUR1630A
I don’t see pricing for the A sets; different??
Old Apr 22, 2023 | 06:34 PM
musicmafia's Avatar
2015 ML350
From what I remember, about $12 apart maybe?
Old Apr 22, 2023 | 07:54 PM
BlackML550's Avatar
2010 ML550 VIN WDC1641722A564750, 2010 B180
Keep in mind that the MLs have 3 rotor sizes. 325mm (standard), 350mm (ML500) and 375mm (ML63). Pads different for each most likely? Im not sure but something to be aware of. Some sites show the dimensions of the pads so look there
Old Apr 23, 2023 | 08:30 AM
Potrice's Avatar
2013 ML350 Bluetec, 1966 Ford Mustang Convertible (sold)
What BlackML550 said is correct. Make sure to check which rotor size goes on your SUV. Mine is a 2013 ML350 bluetec but uses the 350mm because I have the AMG sports package.
Old Apr 23, 2023 | 10:48 AM
Leetom's Avatar
2013 ML550 US spec. Air+Offroad pkg
Probably said somewhere above, but to save a few $, take rotors to like Oreillys Auto Parts and they will turn your rotors for like $8 (even drilled ones). They measure 2 make sure enough material on to not go below spec. If doing rears, make sure to do the brake release/retract procedure on your dash buttons to prevent breaking the screw gears back there. I have procedure somewhere if u dont have it.
Old Apr 23, 2023 | 04:20 PM
musicmafia's Avatar
2015 ML350
Yes, I would love to have this to provide to the shop just in case. Thanks!
Old Apr 25, 2023 | 06:45 PM
  #32
musicmafia's Avatar
2015 ML350
I looked up the rear electric brake procedure in another thread and will take a copy to the mechanic.
Old Apr 25, 2023 | 06:49 PM
  #33
Leetom's Avatar
Sorry about that. You should do brakes yourself. Isnt a hard job, and save a bunch of $.
Old Apr 25, 2023 | 09:38 PM
  #34
musicmafia's Avatar
2015 ML350
BTW Are the inner and outer pads identical or are they slightly different (to accomodate sensors maybe)?
Old Apr 25, 2023 | 09:49 PM
  #35
BlackML550's Avatar
Inner and outer pads are different. Backing plates vary (one clips into the piston with a metal claw, the other simple rides on the caliper) and they will have a slot on the top alignment about half way along for the wear sensor. You can't mix them up - they only fit one way and you'll see this when you get the pads.
Are you going to do them yourself?
Old Apr 26, 2023 | 03:26 PM
  #36
musicmafia's Avatar
2015 ML350
Thanks. No, I'm running a business full time, still trying to dig out of covid, so I don't have the time. If it was just pads I might attempt it, but they are going to resurface the rotors for me, whereas the other shops (that I had not done business with before) wanted to replace rotors that are still in spec, which felt like a hustle. I've worked with this shop before with multiple cars and they've always been fair. All I had to buy was F/R pads kit and their labor fee is much more reasonable than the MB specialty shops ("reasonable" given that we're in CA, where nothing is reasonable and everything tends to be more expensive than other areas). Dealer quote was $2600 (!), indie specialty shop quote was $2100 (also ridiculous), so I feel good with my old shop, all-in (parts, labor, resurface) for around $600. Dropped it off today.
