Cold start noise normal?
Old Jul 1, 2023 | 03:06 PM
Gray_Panther's Avatar
ML400 - 128i - Atlas VR6
Hey guys, just looking for confirmation if the first few seconds of noise on a cold start is normal.
https://youtu.be/lwgVLBwnxS8
edit: 77k miles, oil changed every 5-6k miles with receipts proof from previous owner. I have owned since 52k.
Old Jul 1, 2023 | 07:18 PM
JCM_MB's Avatar
2008 E350, 2012 ML350, 2014 E350, 2015 ML350
Would you mind posting vehicle's VIN number?
Old Jul 1, 2023 | 09:38 PM
It falls within the recall for the check valve and the upper timing chain tensioner.
Engine code is 276955 30 302978
Old Jul 1, 2023 | 09:52 PM
JCM_MB's Avatar
It does not sound great, but it is best to compare to the sound 5 min later. If the sound goes away after a 30+ seconds and later sound similar to when it is warm, I would try using 5W40 instead. If the sound improves I would look to get the TSB done.
You do not want that to make further damage which includes first adjusters, then camshafts. @$1000 each per train valve x 2 banks
Old Jul 1, 2023 | 10:29 PM
Thank you. Tomorrow morning I will start the engine and let it idle for a bit, and then recycle a couple times with about 1 min intervals and note the sounds or any differences and report back.
I have been using LiquiMoly 5W-40 predator blood since purchasing the vehicle at 52k. Thank you for the input, Juan!
