New codes after oil change
Codes are P054C, P054A, P0021 and P0014. These are all timing over advanced codes relating to cam position it appears. I pulled the sensors and found oil in 3/4 of them. One was very slight and may have been from him spilling when filling but the others definitely had oil. So I replaced the two driver side sensors and took it out for a test drive.
It drives totally normal. No odd noises. No long cranking. No trouble in general. But the 21 and 14 codes popped up again. The others are showing as permanent but not active.
Course of action? Don't say take it to a mechanic. Glad to have info from mechanically inclined folks. I'll be fixing it.
Is there a cam oil valve somewhere? Or some other part that may have randomly failed at a perfect time. I am inclined to believe it had something to do with the oil change he did.
