Correct ignition coil for 2013 ML350 with 929
Old Oct 29, 2023 | 01:01 PM
xman11's Avatar
2013 ML350
I got a P0304 Cylinder 4 misfire on my 2013 ML350 (with option 929 E85 Fuel). I'm looking to replace the ignition coil. Does anyone know the correct part number?
Or if you recently had a successful repair, can you share the part number used by the mechanic?
Btw, I pulled a few out and they have part number A 276 906 02 60.
I looked up the part online and discovered that it's replaced by 276 906 04 01 - https://mbparts.mbusa.com/oem-parts/mercedes-benz-direct-ignition-coil-2769060401
The fitment notes show it's for 2013 ML 350 3.5L V6 - Gas, but for other models, like E350, also includes 3.5L V6 - Flex.
I browsed more and found some other parts like 276-906-54-00 that says compatible with "2013 Mercedes-Benz ML 350 4Matic®, Base, Bluetec 4Matic® 3.0L V6 - Diesel, 3.5L V6 - Flex, 3.5L V6 - Gas".
I'm guessing the original part A 276 906 02 60 or its replacement 276 906 04 01 is the best bet but wanted to hear from others.
