2013 ML350 4matic door locks intermittent problem
Old Nov 5, 2023 | 01:29 AM
Brett513's Avatar
2013 ML350 4matic
So all of the door locks function manually (plunger up down), and the electronic activation (fob or door button) works on all locks except the driver side passenger (rear seat) lock. When I lock the doors, that seems to work consistently every time. It's the unlock that seems stuck on one door (sometimes). If I manually move the plunger to problem door to unlock it seems to start working again. But I leave to go shopping and when I return I can't open the rear door again without manually moving the plunger. It is super annoying. I don't think the actuator is broken - it seems to work. Please help!!! What's the deal!!
brett
Old Nov 7, 2023 | 03:24 AM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
DOOR... controler or lock
brett
Brett, don't drive yourself into drinking with that door lock.
Hook up a scanner to assess if that door control module is cooperating with lock. Both can go bad just as well.
My fav would be the solderless DCU.
Old Nov 8, 2023 | 10:54 AM
RA112623's Avatar
had this exact problem a couple years ago. service said nothing was wrong but replaced the lock anyway. i have always believed something was wrong. can't offer more than that. good luck, ron
