W166 sway bar bushings, NON replacable
Old Nov 12, 2023 | 03:11 PM
kkarb's Avatar
w164
My w166 has clunking from rear end. It turns out to be the sway bar bushings. BUT, for this model with active curve control (hydraulic tosion bar) these busings is NON replacable. Need to buy new complete sway bar for 3000 Euro.
Any expirience??? This is insane, but true.
is there any known work arround??
Old Nov 12, 2023 | 04:49 PM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
Found these while doing some research for my own, mind you they are poly bushings not original so they will be much stiffer:
https://siberianbushing.ca/product/s...65-11-01-4070/
Old Nov 12, 2023 | 05:15 PM
kkarb's Avatar
w164
the ones at pic do not fit. They ar for ML without active roll sys.
so this is different matter
Old Nov 25, 2023 | 09:46 AM
Potrice's Avatar
2013 ML350 Bluetec, 1966 Ford Mustang Convertible (sold)
Are you sure they are 3k euro? Sounds totally insane. Have you checked Rockauto or Ebay for used?
Old Nov 25, 2023 | 12:11 PM
kkarb's Avatar
w164
Dealer is 3000 Eur, ebay is cheaper ofcourse👍
Old Nov 25, 2023 | 10:47 PM
chassis's Avatar
2017 GLE350 4MATIC
MB stabilizer bar bushes are adhered to the bar with adhesive. Not available as loose items as original parts. Therefore buying the bar is required.
Standard bar is "inexpensive" compared to the EUR 3k two-piece Active Curve stabilizer bar.
