Besy (easiest) place to get a 12v ignition source from?
Old Jan 26, 2024 | 09:16 AM
simongunz's Avatar
1993 SL500 & 2010 GL450
ML400, I'm wanting to put a flush mounted USB C port in the console/dash (with hidden wiring), wheres the best place behind the dash to grab a 12v ignition switched source from ? Ideally if i can remove the radio or AC controls and get access to a wire that would work, just need to know which color wire and where!
thanks
Old Jan 26, 2024 | 10:58 AM
Miki122's Avatar
W166 ML350
The easiest way is to use 12v directly from the "cigarette lighter socket"
Old Jan 26, 2024 | 05:19 PM
mike919's Avatar
86 190E 2.3, 2014 ML350 Bluetec
You can circuit tap into the fuse box on the passenger side dashboard.
Old Jan 26, 2024 | 05:27 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
THAT is a graceful solution to a very common problem. I like it.
Old Jan 27, 2024 | 11:51 AM
mike919's Avatar
Thats the current solution for my Dashcam, works well.
Old Jan 28, 2024 | 04:25 PM
simongunz's Avatar
Thanks for the info, i did the job this morning, 4 bolts to loosen the center console, lifted it up and tapped into the cigarette lighter wiring,
