Keep fluid in after AdBlue delete?
Old Jul 30, 2024 | 06:39 PM
HumW166's Avatar
2012 Mercedes ML250 Bluetec Special Edition W166
I had an AdBlue, DPF & EGR delete + Remap done in June 2023. It just occured to be that I'm not sure if the ad-blue tank was drained or not.
Should it be drained after the delete or, should it instead be filled?
Assuming I don't want to remove the AdBlue tank..
Old Jul 31, 2024 | 10:27 AM
tonyl13's Avatar
ml350 bluetec
I would drain it just added weight, it will go bad after seting for a long time
Old Jul 31, 2024 | 09:36 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
If you ever want to have a prayer of going back to non delete, you'll want the tank COMPLETELY empty and clean. Really can only do that by removing the tank and all the associated plumbing, then plugging the injector hole in the exhaust pipe. If you're not worried about going backwards, drill a hole in the tank and call it good.
