How to turn torque converter on w166
Old Aug 20, 2024 | 11:03 PM
luboreal's Avatar
GLE 450 AMG
Hi all,
I am about to do a transmission service, but I can’t find a way to get the torque converter drain plug in place
WIS call it to use a flat screwdriver, but I was not able to turn it even a bit
Crank pulley is not an option, cos the intercooler is in front and I don’t have access
Any ideas will be appreciated
Old Aug 20, 2024 | 11:28 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Don't bother trying to drain the TC. Just drop the pan and filter and the fluid that comes out therewith, install new filter and gasket with the pan, refill to correct level, done.
If you're worried about the fluid you didn't get out, just do it again in a few thousand miles - or in another 25K. I've done a pan drain/filter change on my big truck every 25K for the last 325K miles and the fluid comes out nice and red each time. I've only done it once on my Benz at 70K miles (should've done it sooner) and the fluid was still clean.
Old Aug 21, 2024 | 08:27 AM
Leetom's Avatar
2013 ML550 US spec. Air+Offroad pkg
What engine do you have? I have the V8 biturbo and a ratchet and socket to the crank pulley from under the car did the trick for me to align the drain hole. Not that hard to turn. There is room to get ratchet in there. I’d definitely drain it, has like 3.5 liters of fluid in it.
Old Aug 21, 2024 | 08:49 AM
luboreal's Avatar
GLE 450 AMG
It is a v6 bi turbo M276. As I mention intercooler is just in front at about a centimeter and impossible to put a tool in there. I actually barely see the pulley
