where is the horn located?
Old Nov 27, 2024 | 06:21 PM
ML400's Avatar
2015 ML400
I'm looking to do a horn up grade and need to know where the horn is physically located. I'm tired of other drivers changing lanes on top of me. I'm planning on adding a smaller (my marine standards) air horn to supplement the factory one. on my other vehicles I wire them up using the factory wiring and add a relay. I also loop the ground thru the firewall and add a switch for ground so I can flip a switch and kill the air horn and still have the factory one. comes in handy if you get pulled over and vehicle inspections.
Old Dec 1, 2024 | 10:13 AM
rapidoxidation's Avatar
2013 ML350 Bluetec
The snarky answer is as follows:
put your ear against the front grill and have someone press the horn button. There's a high tone and a low tone horn, and I bet you can see them from the front.
Old Dec 9, 2024 | 04:57 PM
ML400's Avatar
2015 ML400
that is indeed a snarky useless answer. It is not visible thru the front grill or looking down with the hood open.
Old Dec 9, 2024 | 05:12 PM
OldManAndHisCar's Avatar
W212 E63S Wagon - GSL580 - E63 - E350 - C300
They are behind the thing at the front....you can hear em when someone presses the steering wheel ;-)
Seriously, what are you putting in? I want to upgrade the horn on our Sprinter...its horn is a joke.
Old Dec 9, 2024 | 07:22 PM
W205C43PFL's Avatar
Two options:
Old Dec 9, 2024 | 07:30 PM
ML400's Avatar
2015 ML400
don't forget marine horns. I'm adding an 18" 150db horn as well as a 20" 155db horn, both driven with a small compressor and air tank.
