STEERING WHEEL REPLACEMENT
Old Dec 19, 2024 | 10:34 PM
AMG39's Avatar
Question STEERING WHEEL REPLACEMENT
Hello,
I am looking to replace my 2013 W204 C300 steering wheel with an OEM ML350 steering wheel from the same year. Would it be compatible or does it need something else?
Thank you in advance,
AMG39
Old Dec 20, 2024 | 11:52 AM
drwolf's Avatar
2020 GLE350 2020 Toyota Rav4H AWD XLE
If you can supply some pictures of your current and what steering wheel you want that would be helpful.
Otherwise, depends on the position of the airbag.
Old Dec 20, 2024 | 05:44 PM
lthlc63's Avatar
04 E55, 06 E55, 05 G55, 14 E63s, 12 cls63
I’m assuming you have the same style buttons (square)
if that’s the case yes it’ll swap over. I recommend using your oem buttons along with oem chip from inside the wheel
Old Dec 20, 2024 | 07:20 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Both cars have heated steering wheel? Lane keeping assist vibration?
Old Dec 20, 2024 | 09:53 PM
AMG39's Avatar
Hello all,
Thank you all for the replies, I really appreciate it! I didn't end up going through with it because it turned out the guy lied, and the steering wheel wasn't OEM. It was a copy; a very well made copy though.
Thank you again,
AMG39
Old Dec 30, 2024 | 02:32 PM
drwolf's Avatar
If you wanna upgrade the steering wheel you need to check two things out
1)is your steering wheel equipped with the heated feature?
2)Do you have distronic plus with lane keeping? (meaning it vibrates if you are going out of your lane)
If you answered yes to either or both, it will be hard to change the steering wheel out.
However, if BOTH answers are no.
You can replace the steering wheel, but you will need to purchase the airbag that comes with it.
see this thread:
https://mbworld.org/forums/m-class-w...-retrofit.html
