2015 ML350 W166 gas engine -- MAF location?
Old Feb 8, 2025 | 09:54 AM
brianwhite007's Avatar
2015 ML350 (gas) W166
Exclamation 2015 ML350 W166 gas engine -- MAF location?
Just bought this and doing a bunch of preventative maintenance like trans fluid drain and fill (and torque converter too), new cabin and engine air filters (why is there three cabin air filters?) and want to lean the throttle body and MAF as well (the ML350 has 128k miles, probably never been done). No codes, all is working well. Cannot find the MAF on this vehicle - where an MAF usually resides is what looks like an air temperature sensor, between the main airbox and the throttle body. Any idea where the MAF is location on this vehicle? Never have seen one NOT between the airbox/filter and throttle. Weird. Wanted to spray some MAF cleaner on it as I doubt it's ever been cleaned let alone replaced. Anyone have a picture of where this is located?
Old Feb 8, 2025 | 11:16 AM
chassis's Avatar
2017 GLE350 4MATIC
No MAF. Hot film sensor detects velocity + temp sensor detects temp = mass flow. Boyle, Reynolds and Bernoulli at work here.
There are two cabin filters in three parts:
1. Dust filter
2. activated carbon filter, split into two parts (pieces)
Old Feb 8, 2025 | 11:30 AM
Makes sense then since I could not find one. Never had a MB without an MAF. Go figures!
Old Feb 8, 2025 | 01:40 PM
chassis's Avatar
2017 GLE350 4MATIC
No MAF in most engines these days.
Remember the L-Jetronic flap-style MAF?
