13 ML 550- Need to change coolant temp sensor
I'm looking for some help. I have a 2013 ML550, and I believe it needs a new coolant thermostat sensor. I'm getting codes P0117 and P2377. I searched for its location, and it appears to be in a pretty tight spot, behind the driver-side engine near the vacuum pump. Has anyone had experience changing this sensor? I can't even get my hand in there yet — I haven't tried accessing it from the bottom and wanted to ask you all first. Any help would be greatly appreciated. The part is #40.
What are your codes describing??
It's likely related to the TSTAT unit getting lazy and temperatures not being in range, right??
Does your engine looses coolant: a little, moderately or a lot??
