UV dye to detect AC leak
Old Jul 10, 2025 | 10:14 AM
Lance55's Avatar
2015 ML350
My 2012 ML350 has a coolant leak and I wanted to see If I could find it using a UV dye. The product I'm considering is Enviorosafe Replacement R134a with dye. My question is will it in anyway harm the system or complicate any repair required? Thank you for your interest.
Old Jul 21, 2025 | 05:53 PM
CaliBenzDriver's Avatar
W212 MY'14 M276-3.5NA @75kMi
A/C LEAK DYE
UV DYE should be ok.
The one thing you never want to use is "leak fix" magic.
Double-check your shredder valve ports are not leaking.
