Adaptive high beams inoperative
Does anyone know of typical faults with the adaptive high beams? Just got this unit, works great, except when I flip on the high beam lever it indicates the adaptive high beams are inoperative. I can only turn them on if I rotate the light switch on the dash to the manual position and then flip on the high beam lever (turn signal lever). They just won't lower automatically. Also, where is the control module?
Dealer fixed the airmatic (wouldn't raise or lower), oil change & filter, fuel filter, and did a full brake job (yay!).
Many thanks!
Note that, by design, the automatic high beams do not work below about 14mph. Above that speed they should work but below that speed you have to turn the light switch to manual and flip on the high beams with the lever.
