high pitch noise from dash
Old Mar 27, 2026 | 09:46 AM
robfolland's Avatar
ML63 W166
2014 ML63 car been sitting for 5 days, I opened door and high pitch squeal coming from the dash, not loud, sounds a bit like the squealing in my ears.
Can turn up the radio and can drown out the noise.
turned off stereo unit and air conditioning unit, the noise continued.
disconnected the battery under the seat and the noise continued. (or is the stereo be powered by the battery in the back?
sounds like an air leak under the dash behind the stereo
is this possible?
any ideas on what it is and the resolution?
not enthusiastic about pulling out the stereo but might have to to discover the source of the squeal,
Old Mar 27, 2026 | 12:52 PM
rapidoxidation's Avatar
2013 ML350 Bluetec
Do your hvac flaps move air where you expect them to when you manipulate the buttons?
Old Mar 27, 2026 | 08:03 PM
robfolland's Avatar
ML63 W166
thanks for the reply,
i operated each function including recirculating and total shutdown and didn't make any difference to the noise. im going to start pulling fuses to see if that helps
Old Mar 27, 2026 | 09:50 PM
2013 ML350 Bluetec
Did the air come out the corresponding vents when you switched functions?
