2013 ml550 no trailer lights!!!!!!!!!!!!!
Also, the trailer lights electrical system likely uses the trailer frame as the ground connection to all the lights. If the ground connection between the 4 way connector and the trailer frame is broken or corroded (this often occurs), none of the lights will work. Check the trailer's 4 way connector, the wire, and the connection where it's screwed into the trailer frame.
